Question about thermostat wiring on new boiler
codyr
Member Posts: 12
I’m installing a new Buderus boiler for radiant floor heat and was about to hook up the red thermostat wire to “R” and white wire to “W” but noticed that there is a factory installed jumper between both contacts. Do I just leave this jumper in place and proceed with the wiring connections? Thanks!
That jumper will make the thermostat irrelevant if that is where you are supposed to connect it. What do the directions say?
There is nothing in the directions about connecting the thermostat wires. All it says is “see wiring diagram.” There’s a picture of the jumper in place in one of the manual diagrams which confused me more.
EdTheHeaterMan said:That jumper will make the thermostat irrelevant if that is where you are supposed to connect it. What do the directions say?0 -
What does it say where there is a triangle with a 2 in it?
The triangle with the 2 is the thermostat wires, per the instruction diagramSTEVEusaPA said:What does it say where there is a triangle with a 2 in it?0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
