Question about thermostat wiring on new boiler
I’m installing a new Buderus boiler for radiant floor heat and was about to hook up the red thermostat wire to “R” and white wire to “W” but noticed that there is a factory installed jumper between both contacts. Do I just leave this jumper in place and proceed with the wiring connections? Thanks!
    EdTheHeaterMan Member Posts: 12,506
    That jumper will make the thermostat irrelevant if that is where you are supposed to connect it. What do the directions say?
  • codyr
    codyr Member Posts: 12
    There is nothing in the directions about connecting the thermostat wires. All it says is “see wiring diagram.” There’s a picture of the jumper in place in one of the manual diagrams which confused me more.
  • STEVEusaPA
    What does it say where there is a triangle with a 2 in it?
  • codyr
    edited February 2021
    The triangle with the 2 is the thermostat wires, per the instruction diagram
