I Told You Not To Forget To Turn The Boiler Water Feed Off!
New England SteamWorks
Member Posts: 1,529
But some folks never listen...
newenglandsteamworks.com
1
OMG is that the main vent? Is this your service call? WOW what's the upstairs look like?
Will they be able to just replace the gas stuff (train?) and burners?NJ Steam Homeowner.
Power and gas to the house off, fire department in to pump it out, insurance adjustors...
What a mess.Br. Jamie, osb
Looks like a non-residential type of boiler room. And the floor drains are clogged.
Now what?0 -
This is a wild one...
So this couple purchases a 6 Unit expensive condo in late summer and promptly hires a company to replace the steam boiler. They finish up, the heat goes on a few weeks later, and the whole building shakes from the banging. They call the company and they came back out, but they can only scratch their heads in wonder at the racket. They promise to return with some "ideas".
Being a smart couple, and observing this head scratching, they promptly order a copy of the Lost Art Of Steam Heating. Revisited, of course. There they discover that the header was piped all wrong. They brought this to the attention of the company (who was almost relieved to hear it as they had yet to come up with any "ideas"), and so the company agreed to re-do the header. Which they did, as you see above.
But the racket continued, unabated. Back to the shop they went for more "ideas".
They fiddled here, and fiddled there, making many more trips. All to no avail.
Eventually, we got the call.
You see, they hadn't bothered to read The Lost Art Of Steam Heating. If they had, they would have found this gem in Chapter 2: "Start looking at systems. Get out of the boiler room and look around. Be nosy."
Which is what we did when we got there, and what's probably the best advise in the book for contractors. I still find it amazing how hard it is sometimes to get my own guys to do so. For me, there are always fascinating things waiting to be discovered, secrets waiting to be revealed out there in the shadows and cobwebs. I can't resist.
But I digress. Had they ventured out of the boiler room into the large sprawling basement they would have discovered that a large section of it had a raised floor. And the boiler itself sits in a pit.
Coincidentally, after Dan finished writing the above line, his very next heading was:
The Magic Of The False Waterline
You guessed it, the previously wet returns were now high and dry. And very unhappy about it.
Unfortunately, we couldn't just zip in there and install a false waterline. For one thing they used press fittings on 4" and 5" pipe, and for another the boiler was more than twice the required size.
But, there's always a solution. You'll never guess the occupation of the husband: Attorney.
And so that's where we left it. The attorney goes to work and does what attorneys do. The goal is a new boiler of the proper size, properly piped, with a false waterline.
And then on Monday the water main breaks and the boiler room floods.
Can't make it up.New England SteamWorks
newenglandsteamworks.com0 -
Before The Flood:
So this boiler was to be replaced anyway?0
Only if the legal action was successful.New England SteamWorks
I'm guessing that the water main did not freeze from the combustion air grill inlet.
Especially if building was occupied, large pipe and maybe not that cold outside?
Insurance Co. may look at it and argue freeze damage or is it simply water damage.
Curious to see the pipe when water off and insulation removed.
Considering the potential bill they are going to study the fine print of the policy.1 -
I wonder how insurance will view this, if they replace the boiler? Will the require it to be a one for one, even thought that boiler is the wrong size, or will they allow the correction? I would speculate they'd allow the correction since it should be cheaper, but insurance companies are funny sometimes.0
>>still find it amazing how hard it is sometimes to get my own guys to do so<<
When I was I young my toolkit included strong flashlight,binoculars,camera,&sketchpad.
Still times when I couldn't divine how system was intended to work.0 -
Many years ago,in a High School In Pittsburgh, Pa. the company had the job of rebuilding /replacing the gas/oil burners in an old school building where the boiler room filled up all the way to the next floor with raw human sewage. After the sewage was pumped out and a hazmat company was done with their work someone had to go do the repairs. IT WASN'T ME.0
If you ever have a basement floor covered with sewage, sprinkle several pounds of ground cinnamon over it all, and it neutralizes the smell.—NBC0
Putting boiler in pit is never a good idea0
It's a great idea if you don't have enough A or B dimension.STEAM DOCTOR said:Putting boiler in pit is never a good idea
Any and all water in the basement will end up in that pit. Boiler is a sitting duck. Give homeowner disclaimer. Maybe lower rest of floor or get some sort of sump pump.0
Maybe install a vaporstat. Reduces the A or B dimension requirements.0
Rookie question, but is that two boilers there or one big double unit? If that's a stupid question, don't hesitate to say so..New England SteamWorks said:and for another the boiler was more than twice the required size.
- 50 Industry Classes
