contractor questions
leonz
Member Posts: 1,754
Have any of you had dealings with or problems with
homeowner funding.org out of Scranton. pa as part of Borrel construction.
They came by and looked at our windows and gave us an estimate for replacing 11 of them and I did not get any warm fuzzies as he said he was not going to write down the specs and measure if you want me to go through the 3 day rule to cancel a contract.
I still have 2 days to cancel and I am very apprehensive about it.
Everything about this sounds sketchy and like they are trying to pressure you in to doing something.0
Cancel with a capitol C
report them to your attorney general0 -
Hi, Cancel them!!! Very unprofessional. I'd look up their license with your state licensing board and check with BBB and search them on the web to see what their reputation looks like.
Yours, Larry
ps. I'd be getting three bids also, if this is a job you want to do. With luck, another contractor will be a bit warmer and fuzzier
