contractor questions
leonz
leonz Member Posts: 1,754
Have any of you had dealings with or problems with
homeowner funding.org out of Scranton. pa as part of Borrel construction.
They came by and looked at our windows and gave us an estimate for replacing 11 of them and I did not get any warm fuzzies as he said he was not going to write down the specs and measure if you want me to go through the 3 day rule to cancel a contract.
I still have 2 days to cancel and I am very apprehensive about it.
    mattmia2 Member Posts: 15,574
    Everything about this sounds sketchy and like they are trying to pressure you in to doing something.
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    We're CONtractors with emphasis on the CON. Don't be rushed. There is always time to do it later if it is a benefit for you and the contractor. Being rushed is a red flag. The fact that you're posting here is evidence that you're not comfortable.
    EBEBRATT-Ed Member Posts: 19,567
    @HomerJSmith nailed it
    If it doesn't feel right back off don't be pushed into anything
    pecmsg Member Posts: 6,770
    Cancel with a capitol C
    report them to your attorney general
    Jamie Hall Member Posts: 26,835
    Worse yet -- they probably don't need replacing, unless they are newer cheapies to begin with -- which is likely what you'd be getting.
    Run away.
    HomerJSmithmattmia2
  • GW
    GW Member Posts: 5,137
    I would fly, seems like a spin job
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,005
    edited January 2021
    Hi, Cancel them!!! Very unprofessional. I'd look up their license with your state licensing board and check with BBB and search them on the web to see what their reputation looks like.
    Yours, Larry
    ps. I'd be getting three bids also, if this is a job you want to do. With luck, another contractor will be a bit warmer and fuzzier o:)
