Terminology or Actual Difference
josephny
Member Posts: 355
Wondering if there is a difference between "manifold" and "multi-port tee?"
I see that both manifolds and multi-port tees can be open on both sides or closed on one side.
I see mention of code allowing multi-port tees to be inaccessible after being built (i.e., no access panel needed). Not sure about manifolds.
Thank you.
Hmmm....
Is my question too basic? Or off-the-mark in some way?
That is a really good question, when a tee becomes a manifold? At times it had to do with the type of connections.A union for example, a mechanical connection, compared to a coupling.
Then there is accessible and readily accessible. Accessible allows a door or cover, I think. Might look for a current code interpretation guidebook.
Often it comes down to what the inspector that shows up will accept😉Bob "hot rod" Rohr
Living the hydronic dream1 -
The code requires accessibility when there’s a mechanical joint like a union or compression fitting. In other words, one that can be taken apart with wrenches. Screw joints, press fittings, soldered joints, glue joints, heat fusion, etc. don’t require accessibility.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
I would think valves, especially balancing valves, would turn a multi-port tee into a manifold. But, I'm just a warshed up electrician, so take that with a grain of salt.0
If you use water to "Warsh-Up" I think that Qualifies.ratio said:I would think valves, especially balancing valves, would turn a multi-port tee into a manifold. But, I'm just a warshed up electrician, so take that with a grain of salt.
Thank you guys! I suppose it's safe to to use the term multi-port-tee when it's a permanent/seal and never meant to be accessed or changed (unless it breaks), and use manifold otherwise.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
