Terminology or Actual Difference
josephny
josephny Member Posts: 428
Wondering if there is a difference between "manifold" and "multi-port tee?"
I see that both manifolds and multi-port tees can be open on both sides or closed on one side.
I see mention of code allowing multi-port tees to be inaccessible after being built (i.e., no access panel needed). Not sure about manifolds.
Thank you.
  • josephny
    Hmmm....
    Is my question too basic? Or off-the-mark in some way?
    hot_rod Member Posts: 27,183
    That is a really good question, when a tee becomes a manifold? At times it had to do with the type of connections.A union for example, a mechanical connection, compared to a coupling.
    Then there is accessible and readily accessible. Accessible allows a door or cover, I think.  Might look for a current code interpretation guidebook.
    Often it comes down to what the inspector that shows up will accept😉
    josephny
  • Ironman
    Ironman Member Posts: 7,894
    The code requires accessibility when there’s a mechanical joint like a union or compression fitting. In other words, one that can be taken apart with wrenches. Screw joints, press fittings, soldered joints, glue joints, heat fusion, etc. don’t require accessibility.
    Bob Boan
    josephny
  • ratio
    ratio Member Posts: 4,212
    I would think valves, especially balancing valves, would turn a multi-port tee into a manifold. But, I'm just a warshed up electrician, so take that with a grain of salt.
    EdTheHeaterMan Member Posts: 11,865
    If you use water to "Warsh-Up" I think that Qualifies.
  • josephny
    Thank you guys! I suppose it's safe to to use the term multi-port-tee when it's a permanent/seal and never meant to be accessed or changed (unless it breaks), and use manifold otherwise.
