Furnace not working
simp50
simp50 Member Posts: 2
Combustion air inducer runs continuously when power is on and thermostat off on a Lennox 80 uhh furnace
    EBEBRATT-Ed Member Posts: 15,453
    Disconnect the thermostat wires at the furnace and see if the inducer shuts down. If it does t stat or tstat wiring is defective.
    If it does shut down the control board or relay taht starts the inducer is probably defective
  • ratio
    ratio Member Posts: 3,615
    Open limit?
    SuperTech
  • SuperTech
    SuperTech Member Posts: 2,139
    ratio said:
    Open limit?
    That would be my first thought.  Open rollout or limit switch.  The control board on the furnace should indicate a fault code by flashing the LED, that should point you in the direction of the cause of your problem.
    HVACNUT Member Posts: 5,804
    Inducer fan relay is stuck or shorted closed. Need a new circuit board.
  • mikeapolis
    mikeapolis Member Posts: 46
    Does switching the T-stat to "fan on" turn the blower on?
  • simp50
    Thanks guys looks like I’m gonna have to get a control board
  • Ironman
    Ironman Member Posts: 7,367
    It's probably not the board, but an open limit or flame rollout switch.
    Bob Boan
  • Seabee5701
    Seabee5701 Member Posts: 19
    Bad ignitor.....
