Radiant Heat Panel
seanbeck1
Member Posts: 23
Im a plumber. Not a huge amount of experience with heating and boilers. I work mainly ICI.
Recently finished a home project of updating my cast iron radiant heat system. Home was initially controlled with 1 thermostat. Wanted to have control of all three floors independently.
Some input from the experienced heating guys would be appreciated!
Nice work.Bob Boan
It’s a Slant Fin Galaxy 100MBTU Conventional boiler. Do you mean protection from expansion? If so, the expansion tank is hidden in the ceiling.Youngplumber said:It looks really good. What kind of boiler? It looks like a standard type. How are you protecting it? I think most people here would like to see the circulator on the supply side pumping away from the heat source if you do have a standard boiler.
(I realize this is over simplified)0 -
Yes although being a plumber, this is where my lack of heating experience/knowledge comes in. In hindsight I probably should have put the air scoop on the supply. Seems to be working great though. No issues.hot_rod said:Nice piping. Odd to see the air purger on the return. Is the expansion tank connected to the purger?0 -
@seanbeck1
Really nice job. The consensus is to pump away from the boiler supply with the expansion tank and air scoop/make up water in between.
Really nice, in fact I don't see any solder on some of those joints0 -
When are you going to solder it?
It looks great. What are your typical return water temps?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Thanks! I like my solder joints neat!EBEBRATT-Ed said:@seanbeck1 Really nice job. The consensus is to pump away from the boiler supply with the expansion tank and air scoop/make up water in between. Really nice, in fact I don't see any solder on some of those joints0 -
Yes I’m supplying cast iron radiators. I probably should have put grommets where my Uponor piping comes through the back but I drilled the holes 1/2” bigger. It’s not running antifreeze. Just water.mattmia2 said:Does that still use your CI radiators? I only ask because of the subject of the post. The workmanship looks great. I might put a bushing or grommet where the wires and pex go through the metal plate. Is it running antifreeze?0
