What do you call it?
A sanitary tee is a tee wye. The combination wye and an eighth fitting it's called a combo or combination or Combi. A copper or press fitting with a female side port is a tap tee if the female port is on the run of the tee it is a tap 90 unless the female port is 1/8 in then it is a baseboard 90 or baseboard elbow.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
A gazinta fitting is a street fittings
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating2 -
Does anyone call flexible metallic conduit "greenfield" anymore?0
Desanco, chase fitting, or trap adapter?0
Here is one tossed at me this morning- Plant electrician running rigid conduit asked me if we had any "three piece couplings".
After he described one, I asked if he meant: a union? "YES! We call them three piece couplings!"0 -
Ha! Ever see Sparky use a '2-hole coupling'?0
OK I'll biteBillyO said:
usually kept next to the henwayCharlie from wmass said:What you send a new apprentice to look for when they cut the pipe too short. Pipe stretcher.
What's a Henway?
And do you keep both of them in the Pyecost?
@EdTheHeaterMan about 5 poundsCost is what you spend , value is what you get.
cell # 413-841-6726
i don't have a duct stretcher but i think i could rig up a substitute if needed0
After sending the helper to the supply house for a pipe stretcher for the pipe you cut too short, (and he figuring out he got played) don't expect him to believe there is such thing called a duct stretcher. It ain't gonna happen!
You got to call it a duct puller together thingy
Ask me how I know?
2 -
What did he mean by a dutchman? Normally a dutchman is a splice or patch in wood.0
Way back when I was a helper, a Dutchman was mostly a cast iron term, it was a piece of cast iron without a hub. When you're working with cast iron you never throw anything away until the job is done. It would be used in the venting system, or in this case from the closet bend to the closet flange.1
So is this what you'd use in a well to increase contact of a sensing element to the well that is nonhardening?
https://www.supplyhouse.com/Refrigeration-Technologies-RT910T-Silicone-Grease0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
