gravity hot water boiler replacement
Gasper
Member Posts: 148
Is it possible to replace a cracked hot water boiler that was heating by gravity, with a new cast iron boiler, and continue to heat without a pump? A customer is requesting this, if possible. Thank you for any feedback.
You could and I have done it. I used a H B Smith BB-14 which was a large water content boiler. That was probably 40 years ago and it worked fine.
Not sure you could find a boiler with a large enough water content today.0 -
That would be more trouble than it's worth. Why would someone wanna do this?
A properly sized and installed mod/con works great on old gravity systems.Bob Boan
The tappings in a modern boiler probably are not large enough for gravity flow. Pick a boiler and call the manufacturer and ask them0
I've seen it done with a cast iron Peerless boiler.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Tapping sizes were my first concern. Water volume of new vs old probably pretty important as well?0
We also, occasionally, have people asking if new boiler can be retrofitted with a power pile (like the old boiler they have) system. Any thoughts on that?0
@Gasper
I am sure a power pile conversion could be done they still use them in gas fireplaces etc.
But, I am also sure it's not really legal1 -
I'd buy one.
Simple. Less to go wrong. Could be used off-grid. Would work in power outages. Smaller generator, smaller battery bank, smaller solar array.
What is the MTBF for a Mod-Con? 12 Years?
My current working Boiler is 70 years old.
The older gas valves with the knob underneath to manually open them.0
