gravity hot water boiler replacement
Gasper
Gasper Member Posts: 148
Is it possible to replace a cracked hot water boiler that was heating by gravity, with a new cast iron boiler, and continue to heat without a pump? A customer is requesting this, if possible. Thank you for any feedback.
    pecmsg Member Posts: 7,064
    Why?
    Ironman
    EBEBRATT-Ed Member Posts: 20,177
    You could and I have done it. I used a H B Smith BB-14 which was a large water content boiler. That was probably 40 years ago and it worked fine.
    Not sure you could find a boiler with a large enough water content today.
  • Ironman
    Ironman Member Posts: 7,903
    That would be more trouble than it's worth. Why would someone wanna do this?
    A properly sized and installed mod/con works great on old gravity systems.
    Bob Boan
    The tappings in a modern boiler probably are not large enough for gravity flow. Pick a boiler and call the manufacturer and ask them
  • I've seen it done with a cast iron Peerless boiler.
  • Gasper
    Tapping sizes were my first concern. Water volume of new vs old probably pretty important as well?
  • Gasper
    We also, occasionally, have people asking if new boiler can be retrofitted with a power pile (like the old boiler they have) system. Any thoughts on that?
    @Gasper
    I am sure a power pile conversion could be done they still use them in gas fireplaces etc.
    But, I am also sure it's not really legal
    Gasper
  • WMno57
    WMno57 Member Posts: 1,408
    I'd buy one.
    Simple. Less to go wrong. Could be used off-grid. Would work in power outages. Smaller generator, smaller battery bank, smaller solar array.
    What is the MTBF for a Mod-Con? 12 Years?
    My current working Boiler is 70 years old.
    mattmia2 Member Posts: 16,777
    The older gas valves with the knob underneath to manually open them.
