question on COLD steam pipe wet
Chris_108
Member Posts: 27
Hi guys,
I have a room above my garage in which the vertical steel piping runs up my garage wall to get to the room above the garage. It had always been boxed in and I had to remove the framing to fix an old water spicket that was that was next to it....
I noticed the piping is wet at the elbow where it makes a 90 from coming horizontal into the garage to a vertical run that goes up my garage wall....
I first thought pipe was leaking but more I think about it is it possible this is just the hot steam condensing against the ice cold steel pipe could cause this to look like a leak?
My garage has no heat so it is very cold (probably in the 40s) if I had to guess. It's not alot of water but enough to where if I touch the pipe I can feel it is wet and I see a few drops on the floor...
I had it insulated but the insulation was wet so I removed the insulation at the elbow. The pipe is definitely old but I see no visible holes....
In a nutshell my question is can steam condense on a much colder then usual pipe?
thanks in advance,
Chris
thanks in advance,
Chris
And an elbow like that is a very common location for a leak. You won't see a hole -- it will be seeping through the threads.Br. Jamie, osb
Thank you. That answers my question.. I have a leak somewhere.. UGH!!
I guess I had wishful thinking LOL
thx again
Chris0
