Outdoor pool calculator
Zman
Zman Member Posts: 7,611
Does anyone have a calculator for figuring the heat loss for an outdoor pool or spa. There are tons available that will do simple temp rise. I am looking for one that will determine evaporative and heat loss under any conditions.
Thx in advance.
Carl
Albert Einstein
    EdTheHeaterMan Member Posts: 12,102
    Are you looking for a calculator that will work when it gets wet?
    I understand the new iPhone is water-resistant and has a calculator function and also takes really good pictures.
    Jamie Hall Member Posts: 27,289
    Heat loss is not that hard to calculate. Evaporation more so -- and more significant.
    That said, here is a handy dandy discussion with useful numbers...
    https://www.engineeringtoolbox.com/heat-loss-open-water-tanks-d_286.html
  • Zman
    The calculator itself does not need to be in the water. A spreadsheet would be ideal. :/
    Albert Einstein
    hot_rod Member Posts: 27,385
    I've always understood that the air movement, wind across the surface is a big variable and hard to assume or predict a number? Would that be called infiltration :)?
    Wind screens or fences were added to pools at the various ski resorts I have worked at to lower the heating loads.
    And keep the riff raff out.
