Outdoor pool calculator
Zman
Member Posts: 7,611
Does anyone have a calculator for figuring the heat loss for an outdoor pool or spa. There are tons available that will do simple temp rise. I am looking for one that will determine evaporative and heat loss under any conditions.
Thx in advance.
Carl
Thx in advance.
Carl
Albert Einstein
Albert Einstein
Are you looking for a calculator that will work when it gets wet?
I understand the new iPhone is water-resistant and has a calculator function and also takes really good pictures.Edward Young Retired
Heat loss is not that hard to calculate. Evaporation more so -- and more significant.
That said, here is a handy dandy discussion with useful numbers...
https://www.engineeringtoolbox.com/heat-loss-open-water-tanks-d_286.html
The calculator itself does not need to be in the water. A spreadsheet would be ideal.EdTheHeaterMan said:Are you looking for a calculator that will work when it gets wet?
Albert Einstein1 -
Hi, This might help: https://www.tesisat.org/en/heating-load-calculation-in-swimming-pool.html
Yours, Larry0 -
I've always understood that the air movement, wind across the surface is a big variable and hard to assume or predict a number? Would that be called infiltration
Wind screens or fences were added to pools at the various ski resorts I have worked at to lower the heating loads.
And keep the riff raff out.Bob "hot rod" Rohr
Living the hydronic dream0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
