What escutcheon size for 1 3/4" OD pipe? IPS confusion abounds
Motorapido
Member Posts: 314
Help clear my confusion on the size of steam riser pipe escutcheon I need to order for risers measuring 1 3/4" OD. I'm not clear on the difference between IPS and nominal sizing. For instance, an amazon listing shows the following:
Floor and Ceiling Plate Split Flange, Fits 1-1/2 Inch IPS Galvanized Pipe or 2 Inch Copper Pipe.
What do I look for in product descriptions that will confirm that the flange escutcheon will be a nice, very close fit to the 1 3/4" OD of my steam risers?
Home Cheapo and Blowes were very limited in their selection. They had many tiny escutcheons in the tub/sink/toilet plumbing section, but in the iron pipe aisle, all they had in a larger size are marked as 2 inch, and they show way too much slop between the ID of the escutcheon and the OD of the pipe. When I look online, I see references to IPS sizes and to iron versus copper pipe. Very confusing. I'm ordering a boatload of them (cleaning up and preparing a rental property for sale and you gotta have pretty pipe escutcheons everywhere, right?) and I don't want to order the wrong size.0
@Motorapido
for 1 1/4", 1 1/2" and 2" the OD is "about" a 1/4" larger than the nominal size. The nominal size is "about" the inside diameter. There are plenty of charts you can download0 -
That depends on how many coats of paint are on the pipe. If it has been there long enough that 1-3/4 pipe might only be a 1/2" riser LOLJamie Hall said:1 3/4 inch does not correspond to any iron pipe size. 1 1/2 inch iron is 1.900 inches in diameter. 1 1/4 is 1.690.
Order 1-1/4 and 1-1/2 from amazon and return the one(s) you don't use. Also, check out Supplyhouse.com They have a liberal return policy. (not a Democratic Liberal... Just Liberal the way we used to mean it)Edward Young Retired
EdTheHeaterMan said:
So to put the question another way, for one-pipe steam, is the most frequently occurring OD of risers to radiators 1.90 or 1.69? My tape measure informed my lousy eyesight that the riser pipe measures 1.75. I'll guess that the pipe is then 1 1/4 IPS with a true OD of 1.690. Think that's correct?Jamie Hall said:1 3/4 inch does not correspond to any iron pipe size. 1 1/2 inch iron is 1.900 inches in diameter. 1 1/4 is 1.690.
Probably is. However, one simply can't say "the most common pipe size" for one pipe steam. The better installers used what was needed. Others used what was on the truck (or wagon!).Br. Jamie, osb
PlumbingSupply.com has good selection with handy conversions for different pipe schedules0
- 50 Industry Classes
