pressuretrol question. is mine okay?
tumbz
tumbz Member Posts: 101
edited January 2021 in Strictly Steam
is there a way to calibrate a pressuretrol? im trying to set mine to .5 cut in, and about 1 to cut out, but its weird because when i do that, the boiler doesnt run when it calls for heat the next cycle.
i would have to come back and turn the knob until the cutout reaches to about 2 before the system to fire up again.
does the CUT OUT mean the pressure at which the boiler is running at? I installed a new 1-5 gauge and when its steaming, the pressure is about 1 - 1.5. Im having banging in my main pipes, so i figure the lower the pressure, the better.
is this because of a cheap pressuretrol? i attached a picture of mine. It works properly, its just that when i set the cut out to 1, it wont turn on until i up it to 2......
can you guys suggest a better one?
    Jamie Hall Member Posts: 27,316
    In that pressure range, the Honeywell 0 to 4 psi vapourstat is far more precise (repeatable) and usually more accurate -- and is not that hard to calibrate.
    It is very likely that the one you have simply will not reset reliably below the pressures you are working with.
  • tumbz
    due to my hammering and my old pressuretrol not being able to set the steam at a lower pressure, i think ill buy a vaporstat.
    is this model number okay?
    Honeywell-L408J1009-Vaporstat-Controller-Steam-0-to-16-oz to work with my boiler.
    Is this one pipe or regular two pipe? If so, I think the L408J1017 might be more suitable, as it can be set from 0 to 4 psi. The L408J1009 has a maximum setting of 16 ounces, and is more suited to vapour steam systems.
  • tumbz
    i have a 1 pipe steam system. so i should buy the L408J1017 ?
    yes
