Correct vent for steam convector radiator?
DPK99
Member Posts: 14
I've been working on getting my old, one pipe steam system in better shape. Replaced some of the old failing vents on the cast iron radiators with Vent Right #1s. They seem to be doing the job well. However, the kitchen has a convector type radiator and the vent (Hoffman 4a) let's out a whole lot of steam. I've made sure that this radiator has a slight tilt to the valve, but that change didn't help. Perhaps the next step is to try a new vent? However, the specific vent currently installed, the Hoffman 4a, is stated to be a "main" vent that is rated for 10psi, whereas the other cast radiator vents are 3psi and I believe that the boiler is even lower. Is the same Hoffman 4a the vent I need for that convector radiator? If not, what type do I need?
If the vent is letting out steam, it's time for a new one. I the radiator heats as you would like, I'd just replace like for like. Don't worry about the pressure rating -- that's a guide to how much pressure they can withstand without going crunch.
On the other hand, if the convector or its feed lines hammer, try going with a slower vent.Br. Jamie, osb
Hoffman 41
New England SteamWorks
newenglandsteamworks.com0
- 50 Industry Classes
