Cleaning a Pigtail???
So I intend to take my P-trol off and install a union with a T so I can add a 30 psi gauge to comply with code.  The union will also make cleaning the pigtail easier in the future.
I'm probably going to just replace the pigtail....but for future reference I want to buy the appropriate brush to clean it out.  I'm having a hard time finding a long flexible brush for cleaning a 1/4" pigtail.
Can someone point me in the right direction?  Thanks!
    EBEBRATT-Ed Member Posts: 20,142
    There is no brush I know of. Some use a wire or a plastic zip tie to loosen up the crud and the blow it out.
    Use a brass pigtail and fittings
    kcopp
  • AdmiralYoda
    AdmiralYoda Member Posts: 793
    Thank you @EBEBRATT-Ed!  I actually answered my own question.  I first searched for pigtail brush, then pipe brush....the correct term is flexible tube brush.  Plenty of flavors out there.
    Quick question...why brass and not black iron?
    The pigtail sits with water in it and the iron ones will plug up a lot faster. Brass is more $$ but well worth the price
    Gordo
  • AdmiralYoda
    Thank you!
    ethicalpaul Member Posts: 8,741
    If you clean it out every year or two you won't need a brush because it won't be able to really build up seriously hardened gunk. You'll just be flushing out some dirty water and a bit of soft mud at worst I would think.
  • Gsmith
    Gsmith Member Posts: 444
    I use a large size pipe cleaner (like the kids use for art classes), long wire with fuzzy stuff attached. Also a zip tie can work.
  • Jells
    Jells Member Posts: 649
    Why screw around when the right item costs $5?
    Jamie Hall Member Posts: 27,316
    Because sometimes they can be next to impossible to get off.
  • Jells
    I was talking about the flexible shaft brush, what are you talking about??
    Steamhead Member Posts: 18,458
    This!
    If a steel pigtail is plugged, we replace it with a brass one. It's not worth it to try to clear a steel one.
    Consulting
    If I have a steel one that's plugged (and I had 3 on 1 process boiler) i take it off or cut it off and replace with brass pigtails. If I am out of pigtails. i pipe it with 1/4" fittings and then get back and replace it
