Cleaning a Pigtail???
AdmiralYoda
Member Posts: 798
So I intend to take my P-trol off and install a union with a T so I can add a 30 psi gauge to comply with code. The union will also make cleaning the pigtail easier in the future.
I'm probably going to just replace the pigtail....but for future reference I want to buy the appropriate brush to clean it out. I'm having a hard time finding a long flexible brush for cleaning a 1/4" pigtail.
Can someone point me in the right direction? Thanks!
Thank you @EBEBRATT-Ed! I actually answered my own question. I first searched for pigtail brush, then pipe brush....the correct term is flexible tube brush. Plenty of flavors out there.
Quick question...why brass and not black iron?0 -
Thank you!0
If you clean it out every year or two you won't need a brush because it won't be able to really build up seriously hardened gunk. You'll just be flushing out some dirty water and a bit of soft mud at worst I would think.
I use a large size pipe cleaner (like the kids use for art classes), long wire with fuzzy stuff attached. Also a zip tie can work.0
Why screw around when the right item costs $5?0
Because sometimes they can be next to impossible to get off.Jells said:Why screw around when the right item costs $5?
I was talking about the flexible shaft brush, what are you talking about??Jamie Hall said:
1 -
This!EBEBRATT-Ed said:The pigtail sits with water in it and the iron ones will plug up a lot faster. Brass is more $$ but well worth the price
If a steel pigtail is plugged, we replace it with a brass one. It's not worth it to try to clear a steel one.Baltimore, MD, USA
Consulting0 -
If I have a steel one that's plugged (and I had 3 on 1 process boiler) i take it off or cut it off and replace with brass pigtails. If I am out of pigtails. i pipe it with 1/4" fittings and then get back and replace it0
- 128 Chimneys & Flues
