Ventilation left behind from old radiator?
ryceratops
Member Posts: 3
So I just bought a condo where apparently prior owners had the old radiator removed and replaced with a heating cooling system that you can see in the pictures.
It appears that the pipes were capped off, painted over, and weird little bumpers placed on top of them. However there is also a small vent that is on the floor behind where it was that looks like maybe it was an exhaust? Out on my patio there is another vent and the air seems to be coming through the two openings. (You can yell in the hole and be outside on the patio and hear it through the vent like a microphone lol.)
It wouldn’t be an issue except the neighbors are apparently smokers and when they are smoking it blows through into my apartment through that hole.
I want to seal it off, but I don’t know enough about old radiators to know for sure if this will be dangerous or an issue down the line if I do.
Anyone know anything about this type of issue or if I should reach out to some type of professional?
In the bedroom they also installed a new ac/heating unit and it had all of the wires covered with a makeshift box that I would like to replicate in the living room after I make sure that covering the vent isn’t going to be a problem. There doesn’t appear to have been a radiator in this room and there is no vent to outside.
Attached is the link to a bunch of pictures I took.
Thanks!!
Some pictures may help
Sorry it’s hard to see but there’s a link to imgur a few lines of space down from “Thanks!!”It’s in orange0
My first thought was old dryer vent? I would get a can of spray foam and do a little at a time, it really expands and sticks to everything also tape plastic on floor and wall so you can clean it up if it overflows. Simple fix for now is to stuff a towel in it.0
- 50 Industry Classes
