Coal Auger
slkl
Member Posts: 1
Looking for a company that repairs or installs coal auger and gear box systems for steam/ hot water boilers.
Got a Delorean?
Just one system or do you have a bunch.
Actually there are a few guys on here into coal and I'm sure one will have some resources.There was an error rendering this rich post.
Cant imagine there's much demand for them anymore.
Augers are still in use in commercial ice making and the vineyard industry.
EFM maybe
https://www.efmheating.com/index.php/dealer-locator
https://www.youtube.com/watch?v=UL0JWGjyil8
What type of system, and where are you located?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Marks Supply Shenadoah, PA for coal stoker parts.
What brand of coal stoker do you have??0 -
Augers and gearboxes are pretty standard on some industrial equipment for bulk powder and solids. Some shops specialize in building them. Any good machine shop could build a auger if you have specs for the flights, shaft and pitch.0
Machine shop could likely rebuild the gearbox too.0
How big is this coal boiler system and what make is it? CS&E in Pittsburgh, Pa. installs and services larger units for both hard and soft coal plus other off the wall systems including units that burn almost any kind of burnable products including saw dust, and burnable chips. Their phone number is 412-821-8900. If they can't help you they may be able to direct you to someone who can.0
