leaking
Mark929
Member Posts: 72
one more time. Leaking old steam radiator from bottom. Ordering replacement - 2-weeks out. In the interim, as I need to heat the room a bit, anything to do to reduce water (dripping into pan) as we're dumping the water q 6/8 hrs? Valve, air valve, ? thanks
If drying it out and removing as much paint and rust and what not as possible from the entire circumference of the joint that's leaking and then covering it with JB Weld's marine epoxy... no bright ideas.Br. Jamie, osb
@Jamie Hall any thoughts on type of replacement. $600 for used in Malden and ? Pex universe sells new replacements in NJ - uncertain what to vie for? thoughts?0
In NJ I had no problem finding two nice rads for $50 each on Craigslist from a guy doing a gut reno of an old house
Here are some places where you can buy used radiators: https://heatinghelp.com/systems-help-center/where-to-find-used-radiators/
President
HeatingHelp.com1 -
never tried furnace cement on a radiator... but I'm thinking it would work for a couple of weeks...
anyone confirm this?0 -
I'm thinking something from the jbweld/filled epoxy family would be the thing to try. Isn't there like an epoxy soaked cloth patch kit for automotive radiators? Maybe a JB weld radiator weld kit.(even though it is for automotive radiators, maybe it would work on a heating radiator).0
Or the JB Weld marine weld product -- the only disadvantage of which is the working time is very short.mattmia2 said:I'm thinking something from the jbweld/filled epoxy family would be the thing to try. Isn't there like an epoxy soaked cloth patch kit for automotive radiators? Maybe a JB weld radiator weld kit.(even though it is for automotive radiators, maybe it would work on a heating radiator).
Whatever, with all of these, the secret is to get the surface you put them on really really clean. Bright metal, no grease or oil, etc.Br. Jamie, osb
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
