Too much for Vegas?
Steve Minnich
Member Posts: 2,868
Not in my opinion π
Steve Minnich
π I think Iβm just going to upgrade the existing AC systems.
Added some detail and flipped the DHW circ. Forgot to do that before the first pic.
Steve Minnich0 -
I like the design and the software sure is pretty.
The indirect circ sure is a long way from the PONPC. I think I'd flip it to the supply."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Point taken. The bulk of this is already piped on painted sheet of 3/4β plywood. I havenβt even bought the indirect yet and the tank/makeup water assembly is on a separate 2β x 4β sheet not yet tied in. Options abound.Steve Minnich0
Is that bad?Steve Minnich0
