steel pipe threading between joists and on installed heating branches
tecsol1
Member Posts: 11
How common is it to thread steel pipe between floor joists or on existing radiator branches to repair fittings without removing the existing pipe and fittings, which are closed up?
Thanks in advance!
Thanks in advance!
Much easier to use a mega press to make connection those tight spaces. If I much to run, I’d use copper. Do you have a exposed MPT end you can work from?0
No, no exposed end, that's the issue0 -
How about some pics?
You can almost always break a fitting with two hammers or by cutting and/or grinding it.
Depending how tight the quarters are, a pony threader like a Rigid 700 or Milwaukee 18v.Bob Boan
We thread them all the time if at least 10-12" between joist and pipes are not right against joist. Of course if there is a fitting up in joist we grind off and reattach. They are a bit tricky sometimes. We are doing a repipe right now that I have 4" between joists where 3/4 drops through joist to below ceiling level. No can do unless GC wants to cut out joist and sister one up after. Not on this one but they have many times. Good luck.
Tim0 -
“ No, no exposed end, that's the issue”
No idea what you’re referring too. Really need a picture.0 -
The connections on the left side are feed on the right, radiator to first floor on the left, and 2nd-floor feed in the middle. The right side connection, hard to see, are the return version for the same. The two tees are what burst.0 -
I see only two realistic options:
1. IF you can fit a pony threader in there, you're gonna have to add unions to be able to reconnect everything.
2. Mega Press would not require unions and looks like the better option.
Either way, you'll probably need to open up more of the ceiling for better access. Patching a larger section shouldn't really cost much more, but trying to repair the pipes without proper access certainly will.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.3
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
