argo arm 6p transformer leaking oil
hi, my furnace has not been igniting when there is a heat call, and it works after I restarted everything. Opened the argo box, found there is oil on its 30va transformer, the argo will need to be replaced right? thx.
  • pawnyou2020
    pawnyou2020 Member Posts: 7
  • STEVEusaPA
    You can replace that transformer, if that is in fact what's 'leaking'.
  • pawnyou2020
    thank you for the help. does it look like the transformer is leaking oil which would cause the e fuse to blow intermittently?
  • STEVEusaPA
    I can't tell anything by your picture. Fuses usually blow from surge/shorts or bad cube relays.
  • pawnyou2020
    what does the grease material on the transformer look like? at first I was pretty sure it is transformer oil leak. thx
    pecmsg Member Posts: 7,026
    That is a dry transformer. No oil.
  • pawnyou2020
    thx. any idea what the grease material is?
    Jamie Hall Member Posts: 27,257
    At a guess, varnish. There to help keep the laminations together and reduce hum.
  • JUGHNE
    JUGHNE Member Posts: 11,548
    Is the oil wet, sticky or dry? As said these are dipped in a form of varnish to seal the unit.
  • pawnyou2020
    it is dry. so I guess the transformer is solid so it is not the issue? it is normal for the 30va transformer makes a humming sound right?
    It's dry? It's varnish. And yes, it is normal for a transformer to hum. Some more so than others. While it is possible to build a transformer which doesn't (at least as much) the efficiency is much worse -- or the cost is astronomical. Or both.
  • pawnyou2020
    back to square one for me. bummer. thx for all the help. guys.
