Estimated Electric Meter Readings
deyrup
Member Posts: 62
Curious if anyone had this happen to them before. We have National Grid as our electricity provider and there was an electric base board heater switched on for a month by accident in October so the electricity bill was high (724 kwh) and they had someone read the meter so that number is accurate. We switched off the heater in November and National Grid didn’t send someone out to read the meter so they estimated the bill as high again even though when I read the meter usage is low (169 kwh).
We ended service at the end of November so we won’t get any credits back the next time they read the meter. National Grid won’t send someone to read the meter until another 8 days into the cycle so now we are stuck paying for whatever usage the current tenants uses until they read the meter, and seriously hoping that they don't switch on the electric baseboards. When I called National Grid said there was no way to manually enter the meter usage, even though their website claims that is possible, but the link is dead.
So.... looks like you’ll have to wait.
Normally wouldn't you end your service with the utility and make the tenant get service with the utility?0
In the past I have been able to read the meter over the phone to a utility when I didn’t like their estimate
I'm quite sure the PUC only allows estimated readings in certain circumstances. However they are not allowed to charge you for electricity which you haven't used.
You will get a credit. Hopefully you have a picture of the meter (along with its serial number which is/was attached to your account) that would be sufficient for the credit.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
I did take a picture, but evidently they will only accept a read from a technician. It seems like they take wireless readings, because no one has ever been in my basement and there are no meters outside; so I don't understand why they can't just take another reading remotely. To put this into context this is hundred of dollars difference in the bill, because they charge $.23 kwh.
@mattmia2 We did end service but we are still on the hook for the bill before the tenant moved in. Tenant moved in on Dec. 1 so we paid for October and November.0 -
Post the pic you have of the meter. I, and a few others, are quite familiar with various electric meters and the aftermarket devices used to make the older ones remote read.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
@Solid_Fuel_Man I looked it up and they use AMI to do remote readings, but that requires people to drive by to pick up the reading. National grid came out and took a reading and I got back half of the bill.
My state evidently blocked installing smart meters for reasons I don't understand.
https://www.greentechmedia.com/articles/read/massachusetts-rejects-smart-meter-rollouts-as-competitive-energy-undermines
- 50 Industry Classes
