Perhaps the earliest programmable thermostat
Nimrod66
Member Posts: 17
Lovely! Probably worked just fine!Br. Jamie, osb
Sounds like a Dr. Emmet Brown idea.0
I saw one one which, when it went off, went bouncing around the room... I forget where I saw it.
On the other hand I had a friend once, decades ago in another country on a different planet, who got so mad at the alarm clock one morning that he emptied an AK-47 magazine into it...Br. Jamie, osb
I remember as a kid in the 1950's seeing an ancient brass wind-up, commercially available device at a boarding house that went off early in the morning to open the damper on the coal furnace central heating system.0
My house was built in 1919 with two pipe steam heat. It has an automatic setback thermostat (no longer operational) made by Minneapolis Heat Regulator Co. Earliest patent date on it is 1907. A clever design; A windup clock with a 24 hour dial on the back. That dial has two pointers that you set for the times to turn up or down the thermostat. The pointers will engage a lever on the thermostat that when tripped will change the setting (high/low) to the other setting. The high and low settings can be set individually. I would be happy to use it if it was functional.0
The nice thing about this era of technology is that there isn't anything inside that a mechanically inclined person can't understand. It's just gears and shafts and a spring, and a little flyweight or some other pendulum-equivalent. That doesn't mean you can necessarily fix what's wrong, but my experience is that 75 percent of the time, once you look it over, it's something easy. The tough cases are the broken springs, stripped gears or missing parts. Other than that, it is usually dirt, corrosion or a minor bend. Or if it is a fancy electrical device, a loose connection (possibly also dirty or corroded or bent).0
Sounds like something from the "little rascals",0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
