system uncertainty
do you service needham area?Charlie from wmass said:Clogged pipe or valves at sight glass would be firt thing to check.
I will be in Methuen this coming week. If you call me I can see if we can fit you into the schedule that day.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
How would I know if I'm loosing some lost water which is traveling into the hot water heater/tank, thus feeder clocking up, adding H2O ?Mark929 said:Need your help again. New Burnham Independence Boiler 'block' - replaced 7 yr older crack one last week - uncertain Model IN# - home 1,700 sq ft. Water in glass site gauge usually fills to 1/3... noticed MacDonald Miller low water cut off light turns red, feeds water most periods I put on heat, thus stopping or slowing the process, I think? Correct? Or is that normal? VXT water feeder I set at '0' at new block install, 5 days ago, now reads 7 - I think for gallons of water? should that be? One thing: daughters room radiator leaks - 1 gallon/week which I empty, and figure into this VXT# equation. Barring that, is this normal? Should I set feeder to add a few more gallon of water from LWCO? Shouldn't water level in site glass be at least 1/2 to 2/3 filled, yet really sits at 1/3? Thoughts? I thought with new block (old crack sent steam up chimney, and VXT feeder ate gallons H2O a day) this new block would eat maybe a few gallons a month, sight glass 1/2+, MacDonald cut off wouldn't be needed each request, and system would seem self contained and efficient. Where am I wrong, what should I look to? You guys have helped greatly in the past -as I don't trust company that installed and now reinstalled this system. Happy Thanksgiving!! Thank you
Just a quick comment on how much water you can lose from a leak. My boiler is 37 years old and I was adding water weekly in the coldest winter months.
We had a radiator that leaked....but it wasn't that bad. A light hissing at pressure and a few drops of water.
I finally go around to rebuilding the radiator.....no more adding water! That "slight leak" added up to a few gallons per week!1
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 52 Industry Classes
