radiator bushings
upstateben
Member Posts: 33
Ive got a couple steam radiators that I want to convert to hot water for a customer. After cutting out the plugs on one side I found they have left hand thread. Does anyone have a source for L-R bushings so I can use these?.
Thanks in advance.
Thanks in advance.
Pressure test them before you do any further work on them to make sure they are usable.Br. Jamie, osb
He can't do that until he finds a fitting for the left hand thread.Jamie Hall said:Pressure test them before you do any further work on them to make sure they are usable.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
I instantly thought of that "There's a hole in the bucket" song
- 87.7K THE MAIN WALL
- 128 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
