Heating the basement
I have steam heat and want to heat my basement . Is it recomended to take hot water from the steam boiler and circulate it through a baseboard system with a circulating pump?
    Jamie Hall Posts: 28,029
    That certainly is much the simplest way to do it. If all the baseboard is going to be below the water level in the boiler, all you need to do is find a convenient tap on the boiler below the water line, pipe from that to a pump, then the baseboards, then back to a wet return somewhere. The control can be just a thermostat to turn on the pump -- although you can get fancy and add an aquastat to turn on the boiler to make sure it's hot. Doesn't take much of a pump.
    ethicalpaul Posts: 9,100
  • Big Ed_4
    Big Ed_4 Posts: 3,590
    Yes, if you heat blow the water line , you don't need a heat exchanger to pressurize the column of water . Just to note circulators get eating up with solids left behind . Maintain and repair any steam leaks
    Even above the water line you don't need a heat exchanger. Broken record mode is on.
