Heating the basement
Gigfy
I have steam heat and want to heat my basement . Is it recomended to take hot water from the steam boiler and circulate it through a baseboard system with a circulating pump?
That certainly is much the simplest way to do it. If all the baseboard is going to be below the water level in the boiler, all you need to do is find a convenient tap on the boiler below the water line, pipe from that to a pump, then the baseboards, then back to a wet return somewhere. The control can be just a thermostat to turn on the pump -- although you can get fancy and add an aquastat to turn on the boiler to make sure it's hot. Doesn't take much of a pump.Br. Jamie, osb
Doesn't even have to be below the water line:
https://heatinghelp.com/systems-help-center/how-to-run-a-hot-water-zone-off-a-steam-boiler/NJ Steam Homeowner.
Yes, if you heat blow the water line , you don't need a heat exchanger to pressurize the column of water . Just to note circulators get eating up with solids left behind . Maintain and repair any steam leaks
Even above the water line you don't need a heat exchanger. Broken record mode is on.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
