Watching a cast iron radiator heat up
hot_rod
Member Posts: 26,468
This is bottom S&R, top sections connected. I ran two 1 hour tests, at 1 gpm, the next day at 4 gpm, very little difference in heat up time or "look"
Interesting how the hot water shoots straight up the first section, travels across the top and heats downward.
What do you use for imaging?New owner of a 1920s home with steam heat north of Boston.
Just trying to learn what I can do myself and what I just shouldn't touch0 -
Flir E40Bob "hot rod" Rohr
Too rich for my blood! but good to see what that resolution actually looks like in person. thanks!New owner of a 1920s home with steam heat north of Boston.
Thought someone got one of the new CAT S61 phones.0
Mine was the old s60. I still have it, it's a pretty rugged infrared compared to the attachment. That said, I'd get the attachment if I was going to do it againYou can have it good, fast or cheap. Pick two0
Yeah, like any tool the more expensive the camera the more features and better quality. Depends on what you use it for, how often, and your budget. Price has come way down. The first IR camera I used, borrowed, was $7,000.00. Belonged to the local utility company and they used it for shooting power lines, connections and transformers for preventive maintenance.
These cameras get used for all sorts of applications, I did a seminar with a Flir trainer years ago in Canada, he showed how stockyards use them for cattle, mad cow disease scanning, and also the cryogenic labs and storage.
Keeping an eye on Walt Disney I suppose
making sure he doesn't thaw before it's time. Bob "hot rod" Rohr
Living the hydronic dream1 -
I'll say it again, Bob... you get all the good tools.
That's pretty cool. Thanks for posting.0
Met a boat surveyor in my area who uses IR to find internal hull damage in the fiberglass. He went on to explain that he also travels around the country inspecting theme parks that have fiberglass scenery and props. His camera is a lot beefier - can't imagine what it costs - but seems like a good investment if you can finagle ways to get paid to use it! I can't get enough of thermal imaging, myself. keep it coming!New owner of a 1920s home with steam heat north of Boston.
Funny story, I was working on a job once when the maintenance man said that they had their insurance adjuster call them up some time ago and excited & said "we just got a new thermal camera to try, can we come out & play around with it at your place?"
I'm sure you can see where this is heading…
The long & short of it was on the way out the door the adjuster said "BTW, here's a list of deficiencies that must be corrected before we'll re-up your policy."
At least, that's how it was explained to me.
be fun to take one up in a drone, look at roofs, solar, ponds, etc.
The power company that I borrowed from had a van with a cutout in the roof that they would sit up under to shoot the powerlines. Looked like the Popemobile.Bob "hot rod" Rohr
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
