Another Steamer Install
EzzyT
Member Posts: 1,377
We we ripped out and oversized and piped wrong steamer along with the hot water boiler that was only doing a single room of baseboard and some toe kick heaters.
Installed a EG50 with tankless coil for the hot water zone.
Also upgraded the main and radiator venting.
Thanks to @clammy for helping us out on this one.
6
Beautiful install!
I like the copper bending work. Is that regular M copper? And if it is do you have to apply heat to get it to bend so neatly?
I don't see a tankless coil. If the hot water loop is just piped off the boiler, why the expansion tank?0 -
@AMservices thanks. It’s L copper and used bending spray. The tankless coil is inside of the front part of the jacket.1
You shake the can first, then apply a liberal amount.
Or you slip the bending Spring over the tube and bend with your hands or across your knee.
I like to slightly over bend and then come back as the spring comes off easier. Some times uncoiling the spring a little relieves the tension to assist removal.......I use them all the time.
Then invert the can and clean the nozzle.....
Something about this Autoconnect program maybe?1 -
I had no idea the tankless was under the front cover. I should have know better to even question you.
You da man0 -
Bending spring seems just as weird.JUGHNE said:You shake the can first, then apply a liberal amount. Or you slip the bending Spring over the tube and bend with your hands or across your knee. I like to slightly over bend and then come back as the spring comes off easier. Some times uncoiling the spring a little relieves the tension to assist removal.......I use them all the time.
I use a yellow jacket crossbow bender but they tell you to anneal hard pipe first.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Springs area awesome for bending. They slip over the outside & keep the tube from collapsing. They're especially useful for bringing linesets out of the wall in a bend in 3 or four axes, where a Ritchie bender just won't fit, even with the reverse bend adapter. You do need to anneal, or use soft copper.
I've never used the spray.
I will not stand for someone talking shhh about the Ritchie bender!ratio said:Springs area awesome for bending. They slip over the outside & keep the tube from collapsing. They're especially useful for bringing linesets out of the wall in a bend in 3 or four axes, where a Ritchie bender just won't fit, even with the reverse bend adapter. You do need to anneal, or use soft copper.I've never used the spray.
I'll sit for it though......Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
By now I assume everyone realizes that the "spray" is actually a "spring".......or is there a spray??
That looks to be 3/4" nominal (7/8 OD) soft copper.
That takes some muscle to do, 3/4" OD kicks my butt sometime, but then maybe I'm getting old.
Older than me, "old timers" told of filling the tubing with sand and then bending it. The sand held the inside ID I guess.
Never tried it myself.0 -
I have one also, but not the reverse attachment.
Needed if you wanted to bend a fixed pipe down.
Need the bender for one install with 7/8 OD, did maybe 4 bends with it. Still like new.0 -
As always a pleasure to work w Ezzy and Fred , always organized and ready to rock and roll w everything u need to get it done correctly no excuses . Aside from my nonsense babbling for some humor not much is ever said just a few question here and there and just plain spinning wrenches and constant paced hard work . It s truely a pleasure working w guys who aren’t afraid to work hard and do it right get It done and then do it again the next day . A true credit to the dying art of quality and true workmanship in a world where garbage Is excepted and accepted daily .peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating3 -
Bob it’s right behind the Adey Mag Filter.Thanks0
I love looking at pictures of your work Ezzy . Just spectacular!gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
Thanks @gerry gill you and many others here on this forum have taught me so much.0
That is a beautiful job guys! What's the black canister on the loop?New England SteamWorks
newenglandsteamworks.com0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
