Vent with no space to remove/unscrew
Roddy
Member Posts: 64
Single pipe steam with all traditional cast iron radiators except for one cast iron baseboard radiator. I'd like to change the vent on the baseboard unit to get it to heat less rapidly/vent slower, but I realized there's not enough space between the vent and the wooden baseboard next to it to be able to unscrew it---it'd hit the baseboard. I realize the vent that's on there had to have been added somehow and I'm guessing there's some kind of add on that you can screw on without having to "spin" the vent, but I thought I'd ask all of you before I start any work on it. Any thoughts?
Can you post a good closeup of the arrangement? Might be able to see something not obvious...Br. Jamie, osb
Nevermind, I misread baseboard radiator for radiator.0
I'm thinking there must be some kind of adapter on there that allows the vent to stay fixed while screwing in/onto the baseboard unit.0
Pictures??0
Happens all the time. You gotta pull the baseboard off the wall a little and spin the valve off.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
Maybe saw the vent off with a sawzall or hacksaw and then take then unscrew the sawed off nipple. Install the new vent with a union.
But as @JohnNY said they put it in there it should come out.
You could also remove the baseboard change the vent and then put the baseboard back in wit a union on the vent0 -
Thank you---again.0
- 50 Industry Classes
