How to troubleshoot ecm motor
Dairon421
Member Posts: 81
in Gas Heating
I ran across a ecm motor today that gave me the flux. If you ran across this motor what will be your steps to troubleshoot it.
I think there are some U tube videos on the subject0
I have an ECM driver which I use to troubleshoot. I'll get you some info when I'm closer.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Just don't use the little key chain with the spinner thing to determine if the rotor is turning. It'll only tell you if the stator is seeing power, generating a magnetic field intended to drive the magnetic rotor.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
