How to troubleshoot ecm motor
Dairon421
Dairon421 Member Posts: 81
I ran across a ecm motor today that gave me the flux. If you ran across this motor what will be your steps to troubleshoot it.
    HVACNUT Member Posts: 7,526
    And the TECMate PRO is a good tool to have.
    ratiorick in AlaskaSTEVEusaPA
    EBEBRATT-Ed Member Posts: 20,482
    I think there are some U tube videos on the subject
  • Solid_Fuel_Man
    I have an ECM driver which I use to troubleshoot. I'll get you some info when I'm closer.
  • Just don't use the little key chain with the spinner thing to determine if the rotor is turning. It'll only tell you if the stator is seeing power, generating a magnetic field intended to drive the magnetic rotor.
