Pex al pex compression fittings buried in ceiling
Turse22
Member Posts: 6
I am adding a cast iron radiator to new second floor room. I am running home run pex al pex through a wall from basement, then between the ceiling joists between the1st and 2nd floor. From there I was going to use pap compression connection to a rigid stub up to radiator.
Question is how does everyone feel about inaccessible compression fittings in ceiling/floor? My gut is telling me to just connect pap right to the rad and have the connection accessible. Just like the look of stub up better.
Crimp fittings? Probably OK.Br. Jamie, osb
Make the connection where an access door can be installed.0
I have never had a regular one fail .... Warmboard approves using a compression when fixing a damaged PexAlPex pipe during install -- they actually send you two. They are buried into the floor! They only approve one crimp type and I have never used the type they show. Any PexAlPex needs two "0"rings in the fitting....
Cross manifolds sends one connection that takes both types -- it has two "o' rings and uses a common copper crimp ring to hold it ... so they must hold with PexAlPex. Very easy if you have the tool.
I understand your fear .... On the projects where I have used panel radiators I did indeed run the PEX up the short distance to the bypass valve on the bottom of the radiator --- used a plastic sleeve to cover some of the first ones I did .... but, really you don't notice them since they come straight up/down.
With the Runtals -- have always done the chrome stubs and burry the compression fitting. It's not like there is a lot of pressure -- like domestic water. I would use the compression and stub if you really notice and need something pretty. It's a tried and true method.
Thanks you guys for your opinions. I don't want to invest in crimp setup. Access door can't be installed as it will be under finished floor and below connection is 1st floor shower.
I think I am going to run it up right to radiator valve and not take risk. I can always sleeve it if I don't like the way it looks or paint it to match rad it will blend in .
Thanks again
2
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
