Yes, another Nest question. Shocker.
![HVACNUT](https://us.v-cdn.net/5021738/uploads/userpics/5EHKT14W9RA0/nHQK739GOJC5C.jpg)
HVACNUT
Member Posts: 5,841
Today I was sent to one of our new construction (now almost complete) homes to install 6 owner supplied Nest E thermostats. Very simple things they are. However, I could not make them operable without having to first download the app, WiFi password, register, the whole nine yards.
I've set up other Nest and Honeywell stats that give you the option to complete those steps later, and still be able to use the thermostat. For whatever reason, the Nest E won't do it. Or more to the point of the thread, did I miss something? Any Nestperts out there who know?
I didn't really delve into it because the foreman said the owners will be out this weekend and they will download and register. The owner is a tech guy so he's sure he'll figure it out. And I'm available if needed.
Thanks
Thanks
Yeah same thing with the Lyric. Has to be set up on the owners phone. Couldn't you just set it up on your phone, then hand off the account, p/w to them?
Perhaps not -- it may require a "cookie" or some other small -- and hidden -- file on the specific 'phone or SIM card.Br. Jamie, osb
@Jamie Hall I don’t know. More than one person (other family member) can have the app/operate the thermostats.
It's a little bit of an atypical situation. Some clients I never even meet or know their name, let alone get their WiFi password. Its seven degrees of separation with some of these people.
I think it's a poor setup. The thermostats are powered and ready to go. There's no reason they shouldn't be able to do what their most important purpose intends. It is first a thermostat, being a toy is second.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
