Outdoor Sensor "shielding"
kcopp
Member Posts: 4,555
I have a condo install for a wall hung IBC boiler.
As we all know the outdoor temp sensor should be installed on the Northside of the house/ building.
This install being a townhouse makes the outside wall a west & east facing walls...
East is not possible to get to.
I am concerned about the sun hitting the sensor late afternoon and giving a false reading.
I have not had this issue before...
Any thoughts on how to be shield this sensor?
TIA.
TIA.
Is there anyway to get it in a shadow, preferably low on the wall?
I have had decent luck mounting them under a lower deck on the sunny side of the building."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Thanks for a thoughts so far.
It is SOG so it step right out onto a patio.
I was thinking about a cover or something.
The wireless would be a neat idea... just not sure on the cost.
I know you said Patio if it was a raised deck you might get under that. How about up under the eves?0
Can you get it under the soffit?
No. Slab on grade. Patio is on the ground.
No soffit.
Under a soffit or as others mention a dryer hood. Tons of heat pumps out there with sensor Sticking out just under the electrical panel.0
Isn't there a wireless option?
Can you get to the roof? North side of the old Chimney?0
In a search for an automotive multimeter https://bestmultimeterreviews.org/best-automotive-multimeter/? You better read this review to know which brand suits your need and budget!..0
No chimney. Can’t get to the roof.0
behind the gas meter? Does it get snowed under?Bob "hot rod" Rohr
Can you staple the wire to the bottom of the siding to get it around the corner? I know it is a bit ugly. If you use round white wire, everyone will figure the cable guy did it
. It is amazing what those guys get away with...
Albert Einstein0 -
I assume that is a privacy fence from the next unit.
Could you mount it on the pole facing the house?0 -
Both good thoughts...
Not sure the next-door neighbor would approve or the association would be happy w/ that.0 -
I have great success for many years with a "Solar Compensated" outdoor temperature sensor used for outdoor reset on a pair of condensing boilers. This is a thermistor in a vertical white PVC tube on the roof that is exposed to free air and the sun 24/7.
The "Solar Compensated" temperature in bright sunshine runs up to 6 or 8º F above the normal outdoor temperature in the shade, and at night runs 2 or 3º F colder than the normal temperature in the shade. Depends how bright the sun is and how clear and cold the night sky is.
Bright sun has a large effect on reducing building heat load and the night-time dark-sky radiation increases building heat load.
The "Solar Compensated" outdoor temperature sensor adjusts for both these effects.
White PVC seems about right, whereas Black or Grey PVC would get too hot in the sun. Never tried silver.
Conventional wall mounted outdoor temperature sensors in the shade can fool you, because they are only measuring the wall temperature in the shade. This would be great if conduction was the only building heat loss - but radiation - heat gain and heat loss also play a significant role.
Just a thought you might want to explore.
Doug in Canada
1
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 385 Solar
