Outdoor Sensor "shielding"
kcopp
kcopp Member Posts: 4,623
I have a condo install for a wall hung IBC boiler.
As we all know the outdoor temp sensor should be installed on the Northside of the house/ building.
This install being a townhouse makes the outside wall a west & east facing walls...
East is not possible to get to.
I am concerned about the sun hitting the sensor late afternoon and giving a false reading.
I have not had this issue before...
Any thoughts on how to be shield this sensor?
TIA.
  • JUGHNE
    JUGHNE Member Posts: 11,508
    I have used a white PVC dryer vent hood to just protect the sensor from the weather.
    If you had some stand off under the hood to keep it in free air and then drilled 3/8" holes in the top of the hood for upward air flow it might work out. Just an idea.
    kcopp
  • Zman
    Zman Member Posts: 7,611
    Is there anyway to get it in a shadow, preferably low on the wall?
    I have had decent luck mounting them under a lower deck on the sunny side of the building.
    Albert Einstein
  • kcopp
    Thanks for a thoughts so far.
    It is SOG so it step right out onto a patio.
    I was thinking about a cover or something.
    The wireless would be a neat idea... just not sure on the cost.
    EBEBRATT-Ed Member Posts: 19,502
    I know you said Patio if it was a raised deck you might get under that. How about up under the eves?
  • STEVEusaPA
    Can you get it under the soffit?
  • kcopp
    No. Slab on grade. Patio is on the ground.
    No soffit.
  • motoguy128
    motoguy128 Member Posts: 393
    Under a soffit or as others mention a dryer hood. Tons of heat pumps out there with sensor Sticking out just under the electrical panel.
  • STEVEusaPA
    Isn't there a wireless option?
  • mikemac52
    mikemac52 Member Posts: 58
    Can you get to the roof? North side of the old Chimney?
  • HotkutExarch
    HotkutExarch Member Posts: 1
    edited February 2021
    In a search for an automotive multimeter https://bestmultimeterreviews.org/best-automotive-multimeter/? You better read this review to know which brand suits your need and budget!
  • kcopp
    No chimney. Can’t get to the roof.
    hot_rod Member Posts: 26,565
    behind the gas meter? Does it get snowed under? :)
  • Zman
    edited October 2020
    Can you staple the wire to the bottom of the siding to get it around the corner? I know it is a bit ugly. If you use round white wire, everyone will figure the cable guy did it :D . It is amazing what those guys get away with...
    Albert Einstein
  • JUGHNE
    I assume that is a privacy fence from the next unit.
    Could you mount it on the pole facing the house?
  • kcopp
    Both good thoughts...
    Not sure the next-door neighbor would approve or the association would be happy w/ that.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    If you can't place the sensor to the north side, you'll have to put a cover (with air space) over the sensor. And you may still have to adjust the heating curve to dial in the sensor location.
    kcopp
    put some bubble foil inside the cover, that will reflect the solar gain, to read just ambient :)
    Zmankcopp
  • ChrisJ
    ChrisJ Member Posts: 17,061
    I'm honestly surprised there aren't more tools out there for this.
    What about local weather data from WIFI for example. Insulated covers to shield the sun etc.
    kcopp
  • Doug_7
    Doug_7 Member Posts: 266
    I have great success for many years with a "Solar Compensated" outdoor temperature sensor used for outdoor reset on a pair of condensing boilers. This is a thermistor in a vertical white PVC tube on the roof that is exposed to free air and the sun 24/7.
    The "Solar Compensated" temperature in bright sunshine runs up to 6 or 8º F above the normal outdoor temperature in the shade, and at night runs 2 or 3º F colder than the normal temperature in the shade. Depends how bright the sun is and how clear and cold the night sky is.
    Bright sun has a large effect on reducing building heat load and the night-time dark-sky radiation increases building heat load.
    The "Solar Compensated" outdoor temperature sensor adjusts for both these effects.
    White PVC seems about right, whereas Black or Grey PVC would get too hot in the sun. Never tried silver.
    Conventional wall mounted outdoor temperature sensors in the shade can fool you, because they are only measuring the wall temperature in the shade. This would be great if conduction was the only building heat loss - but radiation - heat gain and heat loss also play a significant role.
    Just a thought you might want to explore.
    Doug in Canada
    kcopp
