If you simply want a way to turn a 1-pipe Radiator on and off, ......
ted_p
Member Posts: 67
The above comment by @Big Ed_4, in @ConservationCrowley's discussion, Radiator Supply Valve - Why do we need 'em?, reminded me of something that I've been pondering for a while now:Big Ed_4 said:The only way to shut off a one pipe steam radiator is to plug the vent .
If you simply want a way to turn a 1-pipe Radiator on and off, why not just insert a valve, such as this, ....
.... between the Radiator and the Air Vent, like this?
The thing that most appeals to me about this approach, is that the "operator" (which means "tenant" in the worst case) can't cause water hammer by opening the valve part-way.
1
Something to watch for is if steam still makes it to the radiator valve, the packing nut or the union or something is leaking in that area.
I've used similar Ball valves connected to vent lines so all the air can be evacuated through a common vent. Just like in a to pipe steam system.
It was very easy to balance the radiators and turn a couple off.1 -
Thanks Danny!Danny Scully said:Of course this will work. I have radiator elbows and these 1/8” pet cocks on all my rads. In some minor way you could even throttle the rad.
I figured someone would have done this by now, unless there was something I'd overlooked which makes it a bad idea.
Great point!AMservices said:Something to watch for is if steam still makes it to the radiator valve, the packing nut or the union or something is leaking in that area. ......
Emerson Swan 1 8"Angle Steam Vent, Adjustable https://www.amazon.com/dp/B072R1RR46/ref=cm_sw_r_cp_tai_DmWGFbG9Z7KKH
Setting 1 is closed. Very good vents Otherwise. Adjustment range is from approx a Gorton 4 to a Gorton 5. A Common Hoffman 40 is in the middle of that range. That range, combined with lots of main venting, and I can handle the range of my smallest to largest radiators. Larger radiators vents a little faster since they have larger piping. Vapor is pulled towards them faster.
Other than a couple radiators with Maid o Mist 4’s on them, and other with TRV’s, all the rest have these in my house. I can tweak the balance as needed or turn off heat to a room altogether.
I would try a needle valve if I wanted to throttle the RadDanny Scully said:Of course this will work. I have radiator elbows and these 1/8” pet cocks on all my rads. In some minor way you could even throttle the rad.
Located in durham NC.
NPT joints can only be moved so many times before they wear and then need to go further. And further.nicholas bonham-carter said:Hoffman vents will stop the flow of air, when turned upside down-no valve needed.--NBC
3
