==> Steam Heat water getting pushed from top of the gauge glass,one radiator vent spitting out water
LS123
Member Posts: 476
hello,
Question 1 --> I made sure that water level in the steam boiler is with in the two lines on the gas gauge. little while I went back and noticed little bit of water was being pushed back in to the glass tube from the top of the tube sporadically. Also there seems to be few drops that leak very seldomly from the water gauge glass . I was wondering what might be the reason. (picture below)
Question 2 --> This season I noticed that one of the steam radiator spitting out water for a while, then it stops
Thank you all!
\- @LS123
Thank you all!
\- @LS123
Judging by the picture they posted, it's a little older than you.Jamie Hall said:Probably related, anyway. The boiler may be surging. I forget (I think you've had another thread?); how new is this boiler?
3 -
Good morning all and @Jamie Hall !
Boiler is steam, probably 70 plus years. would would cause a this type of boiler to surge once in awhile?
(This used to be coal burning, converted to oil)
hello @nicholas bonham-carter ,thank you. I didn't know pig tail needed cleaning. I am going to try that. thanks again all!0
