Another Steamer Install
EzzyT
Member Posts: 1,379
We ripped out this rotting oversized Utica that was also piped in copper.Installed a Peerless 63-03 with a drop header, water seal.
Just need to go back to finish installing the fan in a can, radiator vents replacements and insulate the near boiler piping.
Thanks to @clammy for helping us out on this one.
Always a pleasure to swing wrenches along side you.
7
Same here Ezzy always a pleasure spinning w you and Fred . It’s always nice to work w these guys ,neat ,orderly and everything you need to do the job right the first time with no short cuts . Only those who do this type of work know all the behind the scene work and time that goes into the job before a wrench or band saw is Out of the truck and ready to work ,it’s not all as easy as one might guess and the time on the job is usually the easiest if you have been doing it long enough . Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
What's going on with the old sight glass? Is it really running at an angle?0
Nice job Ezzy.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 50 Industry Classes
