Would You pipe this differently?
I can't exactly follow the piping from the pics, but I'd pipe both boilers injecting into the house loop through closely spaced Tees. I know it's an extra pump involved, but that way you'd only have to throw a switch to change over. Doing it like that, anyone (your wife family members, etc.) could do it without having to figure a valving arrangement.Bob Boan
That’s exactly what I’m doing. There’s an internal pump in the wall unit and one for the oil boiler with 6 pumps not shown in the ceiling that run the zones.Ironman said:
Just a guy running some pipes.0 -
I am confused. Why is there a minimum distance from the tank? Is it a local code thing? Fire rating?EBEBRATT-Ed said:I am a little concerned about the distance from the boiler to the oil tank. I think 5' is minimum
Rick0 -
Prime candidate for a HydroSepBob "hot rod" Rohr
@rick in Alaska
I know Mass code was always that the tank had to be 5' from the oil boiler. Mass has since dumped there Code and adopted NFPA.
I am not sure what NFPA wants but I am sure there is some minimum distance.
I realize the new boiler is gas but is installed between the oil boiler and the tank....looks pretty close.
Just playing inspector here0 -
Thanks for the clarification. It makes sense where you are. I don't think about it because virtually all our tanks are outside on stands, so no where close to the burner.EBEBRATT-Ed said:@rick in Alaska
Rick0 -
@rick in Alaska
I did look it up in NFPA-31 oil code and it is 5' tank to any source of ignition unlsee you put a 1 hour fire wall in between1 -
So I was inspected today. Oil burner is 10’ and any other ignition source or appliance is 5’ or a 1-hour barrier. He’s asking me to hang some drywall but not secure it and that will suffice. Really nice guy. Passed my gas main.EBEBRATT-Ed said:@rick in Alaska I did look it up in NFPA-31 oil code and it is 5' tank to any source of ignition unlsee you put a 1 hour fire wall in between
Source of IgnitionTimco said:
Electrical equipment is a source of ignition if it creates an arc or spark during operation.
Cir maybe, maybe not. T-Stat YES!
This is all up to the building inspector
Us a thermistor and the boiler's control for the indirect. No switch on the water heater then...
Do explosion proof switches with some sort of shielding still count as a source of ignition?0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
