A clever Calefactio pump iso valve, check ∆P
hot_rod
hot_rod Member Posts: 25,379
1/8" gauge ports, rotating flanges, and you can purge from either side, depending on handle position.
SuperTechGroundUp
    Jamie Hall Member Posts: 26,210
    neat gadget!
  • Ironman
    Ironman Member Posts: 7,731
    Who's got 'em?
    Bob Boan
  • STEVEusaPA
    edited September 2020
    Would you (could you) use that (and maybe a globe valve) instead of circuit setters?
  • Hard to track down, but I purchased mine about a year ago from Hajoca, Salt Lake City (855) 982-1408; ask for Vern.
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    I considered those for my system but went with a single pressure gauge and two ball valves piped in parallel to the pumps. It decreases the margin of error which could be significant for residential applications.
    Steve Minnich
  • STEVEusaPA
    So for the circulator, you close one valve to read one side, and then switch it and read the other side?
  • Steve Minnich
    @STEVEusaPA Yep, and then do the math.
    Steve Minnich
    STEVEusaPA
  • Steve Minnich
    I get that it’s not practical to do what I did on job sites. It’s my personal system and I like bells and whistles. 😎
    Steve Minnich
    STEVEusaPA
    mattmia2 Member Posts: 13,589
    I'd be inclined to pipe the 2 taps to either side of something like a Dwyer differential pressure gauge of a low full scale but higher max pressure value so that you can calculate flow in systems with low resistance.
    When I experimented with trying to measure flow with a single high precision gauge and a 3 way valve to toggle it between the inlet and the outlet of a balancing valve, I was never sure if I was really getting the differential or if the system pressure was fluctuating more than the differential across the valve.
    Or a simple Y hose across the two valves, with the single gauge.
    I only have one valve to demo this :)
  • Steve Minnich
    Yeah I like the idea of using something like that as a test instrument.
    Steve Minnich
    I did basically that. A pump probably has enough delta for that to work. When i did it across a balancing valve it was iffy if the variation was because of the differential across the valve or fluctuations in the pressure in the system at both points.
