Repurposed plumbing art
Hvac_artisan
Member Posts: 21
N
Let me know what you guys think of this one. Anybody else do this type of thing with the old plumbing parts of the takeout? A while ago there was a post on the page about repurposing salvage parts from plumbing and boiler change outs I didn’t have this project finished at the time and can’t find it to repost it in that feed on the wall. This is a project that I made as an anniversary gift for some friends . They have been married 60 years he likes to repurpose stuff and makes yard decorations and clocks out of hubcaps things like that. They spend a lot of time with the flowers and vegetables in the garden so I figured I’d give them some flowers that wouldn’t wilt over the winter. Also I was fortunate to find an all the license plate in my pile of junk that matched the month and year that they were married. I had some old blank valve tags that I use to create a custom one.
5
That's such a creative and thoughtful gift, @Hvac_artisan. Thanks for sharing.
@Steve Minnich, I think you'll like this. I know you've worked on some cool projects like this.President
HeatingHelp.com2 -
Steve Minnich3
I really like those Very creative Regretting I threw away all the parts I did over the yearsRay Wohlfarth
Boiler Lessons1 -
Hi, Here's something. Not elegant, like what @Steve Minnich or @Hvac_artisan does, but heck!
Yours, Larry
3 -
Excellent!Bob "hot rod" Rohr
No more guesses?
It was installed in condo building."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Elevator hardware?Steve Minnich0
Yes, the company that had the PM contract failed to keep the gearbox topped off and the elevator seized during high season. What unfolded after that was an ugly legal battle. After the battle was over they had this commissioned with the parts, the pulley in the middle is part of the safety governor and is included for artistic balance.
The owner is a customer of mine, whenever they talk about differing maintenance, I just point to the table.."If you can't explain it simply, you don't understand it well enough"
Albert Einstein3 -
Wonder why the gearbox needed"topping off" an oil leak somewhere?
Usually you need to be licensed and insured to service elevator equipment, typically not a property managers, or building maintenance skill set
Lots of liability around elevator work. Bob "hot rod" Rohr
These guys were manufacturers technicians who had a service contract on the elevator. They were charging for the work but not checking the fluid levels as called out in the PM agreement."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 123 Chimneys & Flues
