No idea what this is or what it does!
sse
Member Posts: 1
Hi all, I’m wondering if someone can tell me what this is, what it does, if I can keep it going or if I should have it replaced and with what! The house was built in 1940. Thank you so much.
it's a stove for heat , Wood or coal , looks like wood ..
And a rather good quality one, at that. Check the stovepipe, check the chimney and be nice and warm. Even looks as though the clearances are OK.Br. Jamie, osb
On further reflection, if you really truly honestly didn't know what it was, I would suggest finding someone local who does know about wood stoves to show you how to use it, and what kinds of wood to use, and that sort of thing. It's not plug and play...Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
That Kohn name comes up as a British or German brand of stove.
You might want to get a chimney sweep to check it over. Clearances and base construction doesn't look to be current code compliant.Bob "hot rod" Rohr
Funny , I guess generations pass with the unknown . I starting to feel old
stonebutson said:
It's what you use to heat the house while your waiting for parts for your fancy new mod/con
Consulting0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
