How to protect wall where steam pipe enters
bostondan
Member Posts: 19
Thanks in advance for any recommendations how how to solve this issue. We have steam heat with some pipes that are visible outside the walls (which is normal).
In one location a pipe takes a turn too close to the wall to allow for a flange to fit over it, or at least any that I have been able to find. The plaster that was put around the pipe slowly cracks over the course of a season and ends up looking weird. I assume it cracks because the pipe gets very hot.
Any recommendations on how to properly protect the wall at the top part of the pipe in a way that is visually acceptable?
Make your own flat flange. Get creative.STEVEusaPA said:Make something decorative.
What material should the flange be made of? Is some type of thin-cut wood okay?0
I'll give it a shot! Hopefully I can make something that doesn't look ridiculous.0
Or just use a good, flexible caulk between the pipe and plaster.0
To protect the wall Using a hammer and chisel chop away some of the wall around the pipe, large enough to put some pipe insulation (store bought) and plaster or cement the open space around the outside of the insulation.
This would cost no more $20.00
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Thanks for all the suggestions!0
- 50 Industry Classes
