How to protect wall where steam pipe enters
Thanks in advance for any recommendations how how to solve this issue. We have steam heat with some pipes that are visible outside the walls (which is normal).
In one location a pipe takes a turn too close to the wall to allow for a flange to fit over it, or at least any that I have been able to find. The plaster that was put around the pipe slowly cracks over the course of a season and ends up looking weird. I assume it cracks because the pipe gets very hot.
Any recommendations on how to properly protect the wall at the top part of the pipe in a way that is visually acceptable?
  • STEVEusaPA
    Make something decorative.
    Jamie Hall Member Posts: 27,395
    Make your own flat flange. Get creative.
  • bostondan
    bostondan Member Posts: 19
    What material should the flange be made of? Is some type of thin-cut wood okay?
  • STEVEusaPA
    Sure. You could make a box, paint it to match the wall, or put something on it, like a clock, picture, etc.
    Here's a horrible drawing...lol
    EdTheHeaterManluketheplumberCLamb
  • bostondan
    I'll give it a shot! Hopefully I can make something that doesn't look ridiculous.
    mattmia2 Member Posts: 16,889
    Or just use a good, flexible caulk between the pipe and plaster.
    EdTheHeaterMan Member Posts: 12,271
    I think you should keep it simple.
    Just make that pipe look like a signpost... by hanging a sign on it!
    luketheplumberPrecaud
  • dopey27177
    dopey27177 Member Posts: 916
    To protect the wall Using a hammer and chisel chop away some of the wall around the pipe, large enough to put some pipe insulation (store bought) and plaster or cement the open space around the outside of the insulation.
    This would cost no more $20.00
    Jake
  • bostondan
    Thanks for all the suggestions!
